Shop the Holiday Gift Guide
Dell Optiplex 745 Ultra Small Form Factor Side Panel Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
13
Past 30 Days:
79
All Time:
1,361
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Student In Progress
This guide is being worked on by hardworking students.
Introduction
Go to step 1 ↓
This guide will help you remove the hard drive from a Dell OptiPlex 745, model number E6400. You might need to do this if your hard drive has failed or is reaching the end of its lifespan. If you hear the hard drive clicking, it means it needs to be backed up and replaced as soon as possible. If files and folders are disappearing or becoming corrupted, this may also be a sign to replace your hard drive.
Warning: It's important to keep backups of hard drives, because you will lose all of your computer's data if the drive breaks before you can save the data elsewhere.
    1. Dell Optiplex 745 Ultra Small Form Factor Side Panel Replacement, Side Panel: step 1, image 1 of 1
      • Make sure to shut down the computer! Go to the start menu and click shutdown from the power options first
      • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
      Ask FixBot
    2. Dell Optiplex 745 Ultra Small Form Factor Side Panel Replacement: step 2, image 1 of 1
      • Lay the computer on its side; you will see a blue knob.
      • Turn said knob 90 degrees counter clockwise.
      Ask FixBot
    3. Dell Optiplex 745 Ultra Small Form Factor Side Panel Replacement: step 3, image 1 of 1
      • While the knob is still turned, slide the panel case forward about 1/2 inch, and then lift the panel off the computer.
      Ask FixBot
Author
with
donnavon
716 Reputation
7 Guides authored
Pasco Hernando, Team 1-1, Prince Fall 2014 Member of Pasco Hernando, Team 1-1, Prince Fall 2014
PHSC-PRINCE-F14S1G1
11 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 79
All Time: 1,361
