You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
If the keyboard of your Dell Latitude E7440 is damaged in any form, use this guide to replace the trackpad.
The keyboard is the main input device used in operating the laptop. A damaged or worn out keyboard or a keyboard with missing keys can be a hindrance while using the laptop.
Before using this guide, clean the keyboard using a soft cloth so that it is free of debris.
Before beginning, make sure to power off your laptop completely and disconnect from any external power source.
  1. Slide the latch and remove the battery.
    • Slide the latch and remove the battery.
  2. Remove two 3mm screws using the Phillips #0 screwdriver. Slide the access door down and remove. Slide the access door down and remove.
    • Remove two 3mm screws using the Phillips #0 screwdriver.
    • Slide the access door down and remove.
  3. Unplug bottom cables. Remove two 5mm screws using the Phillips #0 screwdriver. Remove two 5mm screws using the Phillips #0 screwdriver.
    • Unplug bottom cables.
    • Remove two 5mm screws using the Phillips #0 screwdriver.
  4. Remove keyboard bezel by using the opening tool to gently pry open the sides.
    • Remove keyboard bezel by using the opening tool to gently pry open the sides.
  5. Remove two 2.5mm screws next to the space bar using the Phillips #0 screwdriver. Remove the mouse buttons carefully.
    • Remove two 2.5mm screws next to the space bar using the Phillips #0 screwdriver.
    • Remove the mouse buttons carefully.
  6. Remove the three 3mm screws that are around the perimeter using the Phillips #0 screwdriver. Slightly jerk the keyboard from one side before pulling it one direction. Slightly jerk the keyboard from one side before pulling it one direction.
    • Remove the three 3mm screws that are around the perimeter using the Phillips #0 screwdriver.
    • Slightly jerk the keyboard from one side before pulling it one direction.
Sheetal Prasanna
595 Reputation
3 Guides authored
IUPUI, Team S1-G1, Stella Fall 2019 Member of IUPUI, Team S1-G1, Stella Fall 2019
IUPUI-STELLA-F19S1G1
4 Members
3 Guides authored
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 81
All Time: 3,069
