Introduction
This guide will show you how to replace the Dell Latitude E5410 keyboard.
  1. Have your laptop ready with the screen pulled all the way down parallel to the bottom of the laptop.
    • Have your laptop ready with the screen pulled all the way down parallel to the bottom of the laptop.
  2. Use the spudger to remove the flat part right above the keyboard.
    • Use the spudger to remove the flat part right above the keyboard.
    • Inside, you will notice that there are a couple of screws that will need to be removed.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  4. Use the Phillips screwdriver to remove both screws. The screw in the middle is  3.85mm and the screw in the middle is 8.66mm.
    • Use the Phillips screwdriver to remove both screws. The screw in the middle is 3.85mm and the screw in the middle is 8.66mm.
  5. Grab the keyboard near the top and pull up and towards the screen. The keyboard should come out.
    • Grab the keyboard near the top and pull up and towards the screen. The keyboard should come out.
2 other people completed this guide.
One Comment
thanks man but its super easy not moderat i have 16 years old and i remove my keybord...
ZendomXGamer ZXG - Reply
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 54
All Time: 2,033
