Dell Latitude D600 RAM (Main Memory) Replacement
  1. Dell Latitude D600 RAM (Main Memory) Replacement, Battery: step 1, image 1 of 1
    • Find the battery
  2. Dell Latitude D600 RAM (Main Memory) Replacement: step 2, image 1 of 2 Dell Latitude D600 RAM (Main Memory) Replacement: step 2, image 2 of 2
    • Pull the tab to release the battery
  3. Dell Latitude D600 RAM (Main Memory) Replacement: step 3, image 1 of 1
    • Pull the battery out
  4. Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): step 4, image 1 of 2 Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): step 4, image 2 of 2
    • Find the panel underneath the microsoft product key sticker, the panel is labeled with an M
    • Unscrew the single screw above the M
  5. Dell Latitude D600 RAM (Main Memory) Replacement: step 5, image 1 of 3 Dell Latitude D600 RAM (Main Memory) Replacement: step 5, image 2 of 3 Dell Latitude D600 RAM (Main Memory) Replacement: step 5, image 3 of 3
    • Pull off the panel to reveal the RAM
    • RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
  6. Dell Latitude D600 RAM (Main Memory) Replacement: step 6, image 1 of 1
    • Once the RAM is popped up, slowly pull it out of the slot
  7. Dell Latitude D600 RAM (Main Memory) Replacement: step 7, image 1 of 3 Dell Latitude D600 RAM (Main Memory) Replacement: step 7, image 2 of 3 Dell Latitude D600 RAM (Main Memory) Replacement: step 7, image 3 of 3
    • To add or replace RAM, place the memory into the slot at an angle
    • Make sure you line it up correctly
    • If it is in correctly it should stay up at an angle by itself
    • Then push down in the middle until it clicks into place
  8. Dell Latitude D600 RAM (Main Memory) Replacement: step 8, image 1 of 1
    • The RAM should be secured by the tabs where the two semi circles are on the RAM
    • If it is not secure, just gently pull it out and try again, use the images to help you out
6 other people completed this guide.
Joseph
1,497 Reputation
5 Guides authored
One Comment
Almost perfect: easy; clear;
Herman - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 2,828
