Dell Latitude 7400 Motherboard Replacement
    1. Dell Latitude 7400 Motherboard Replacement, Battery: step 1, image 1 of 3 Dell Latitude 7400 Motherboard Replacement, Battery: step 1, image 2 of 3 Dell Latitude 7400 Motherboard Replacement, Battery: step 1, image 3 of 3
      • Lay the laptop on a flat hard surface facing downward.
      • Use a Phillips #0 screwdriver to remove the eight 3 mm screws that secure the lower case.
      • Lift the lower case off and set that aside.
      Ask FixBot
    2. Dell Latitude 7400 Motherboard Replacement: step 2, image 1 of 3 Dell Latitude 7400 Motherboard Replacement: step 2, image 2 of 3 Dell Latitude 7400 Motherboard Replacement: step 2, image 3 of 3
      • Use a Phillips #0 screwdriver to loosen the two 3 mm captive screws that secure the battery.
      • The screws will not remove completely, so just loosen them enough to lift battery.
      • Gently grip the battery connector loop and lift it to disconnect the battery connector.
      • Lift the battery up and out.
      Ask FixBot
    1. Dell Latitude 7400 Motherboard Replacement, Motherboard: step 3, image 1 of 3 Dell Latitude 7400 Motherboard Replacement, Motherboard: step 3, image 2 of 3 Dell Latitude 7400 Motherboard Replacement, Motherboard: step 3, image 3 of 3
      • Remove the 2 mm Phillips screw securing the bracket.
      • Lift and remove the bracket.
      Ask FixBot
    2. Dell Latitude 7400 Motherboard Replacement: step 4, image 1 of 2 Dell Latitude 7400 Motherboard Replacement: step 4, image 2 of 2
      • Gently pull the display cable connector and move the power adaptor cord to the side.
      Ask FixBot
    3. Dell Latitude 7400 Motherboard Replacement: step 5, image 1 of 3 Dell Latitude 7400 Motherboard Replacement: step 5, image 2 of 3 Dell Latitude 7400 Motherboard Replacement: step 5, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the screw securing the bracket.
      • Lift and remove the metal bracket.
      Ask FixBot
    4. Dell Latitude 7400 Motherboard Replacement: step 6, image 1 of 2 Dell Latitude 7400 Motherboard Replacement: step 6, image 2 of 2
      • Gently pull straight up on the display press connector tab to disconnect it.
      Ask FixBot
    5. Dell Latitude 7400 Motherboard Replacement: step 7, image 1 of 3 Dell Latitude 7400 Motherboard Replacement: step 7, image 2 of 3 Dell Latitude 7400 Motherboard Replacement: step 7, image 3 of 3
      • Use a Phillips #0 screw and unscrew the seven 3 mm screws that secure the fan and heat sink.
      • Remove the fan and heat sink and set it aside.
      Ask FixBot
    6. Dell Latitude 7400 Motherboard Replacement: step 8, image 1 of 3 Dell Latitude 7400 Motherboard Replacement: step 8, image 2 of 3 Dell Latitude 7400 Motherboard Replacement: step 8, image 3 of 3
      • Remove the three Phillips screws that secure the SSD cover.
      • Remove the SSD cover.
      Ask FixBot
    7. Dell Latitude 7400 Motherboard Replacement: step 9, image 1 of 3 Dell Latitude 7400 Motherboard Replacement: step 9, image 2 of 3 Dell Latitude 7400 Motherboard Replacement: step 9, image 3 of 3
      • Remove the single Phillips screw that secures the WLAN card.
      • Using a spudger tool, gently lift the WLAN card and remove.
      Ask FixBot
    8. Dell Latitude 7400 Motherboard Replacement: step 10, image 1 of 3 Dell Latitude 7400 Motherboard Replacement: step 10, image 2 of 3 Dell Latitude 7400 Motherboard Replacement: step 10, image 3 of 3
      • Remove the the two Phillips screws on the metal bracket beneath the RAM modules.
      • Remove the bracket.
      Ask FixBot
    9. Dell Latitude 7400 Motherboard Replacement: step 11, image 1 of 3 Dell Latitude 7400 Motherboard Replacement: step 11, image 2 of 3 Dell Latitude 7400 Motherboard Replacement: step 11, image 3 of 3
      • Remove the two 3 mm Phillips screws.
      • Using a spudger, gently lift the metal plate and set it aside.
      Ask FixBot
    10. Dell Latitude 7400 Motherboard Replacement: step 12, image 1 of 3 Dell Latitude 7400 Motherboard Replacement: step 12, image 2 of 3 Dell Latitude 7400 Motherboard Replacement: step 12, image 3 of 3
      • Grab a Philips #000 screwdriver and unscrew the three highlighted 4 mm screws.
      Ask FixBot
    11. Dell Latitude 7400 Motherboard Replacement: step 13, image 1 of 3 Dell Latitude 7400 Motherboard Replacement: step 13, image 2 of 3 Dell Latitude 7400 Motherboard Replacement: step 13, image 3 of 3
      • Flip up the locking ZIF locking flap securing the ribbon cable.
      • Disconnect the ribbon cable.
      Ask FixBot
    12. Dell Latitude 7400 Motherboard Replacement: step 14, image 1 of 3 Dell Latitude 7400 Motherboard Replacement: step 14, image 2 of 3 Dell Latitude 7400 Motherboard Replacement: step 14, image 3 of 3
      • Gently pull on the two no-fuss ribbon cable connectors straight out of their socket to disconnect them.
      • Gently grip the sides of the two JST connectors and pull straight away from the socket.
      • Remove the CMOS Battery and set it aside.
      Ask FixBot
    13. Dell Latitude 7400 Motherboard Replacement: step 15, image 1 of 2 Dell Latitude 7400 Motherboard Replacement: step 15, image 2 of 2
      • Gently grab and lift the old motherboard and set it aside.
      • Get a new motherboard and place it in the space where the old motherboard was.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 79
All Time: 533
