Dell Latitude 7400 Battery Replacement
    1. Dell Latitude 7400 Battery Replacement, Battery: step 1, image 1 of 3 Dell Latitude 7400 Battery Replacement, Battery: step 1, image 2 of 3 Dell Latitude 7400 Battery Replacement, Battery: step 1, image 3 of 3
      • Lay the laptop on a flat hard surface facing downward.
      • Use a Phillips #0 screwdriver to remove the eight 3 mm screws that secure the lower case.
      • Lift the lower case off and set that aside.
      Ask FixBot
    2. Dell Latitude 7400 Battery Replacement: step 2, image 1 of 3 Dell Latitude 7400 Battery Replacement: step 2, image 2 of 3 Dell Latitude 7400 Battery Replacement: step 2, image 3 of 3
      • Use a Phillips #0 screwdriver to loosen the two 3 mm captive screws that secure the battery.
      • The screws will not remove completely, so just loosen them enough to lift battery.
      • Gently grip the battery connector loop and lift it to disconnect the battery connector.
      • Lift the battery up and out.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 30
Past 30 Days: 125
All Time: 854
