Introduction
This guide shows the process of how to disassemble and remove the motherboard from the chassis.
Orient your laptop so that you have access to the lower case, with the vents facing upwards.
Use a Phillips screwdriver to loosen the eight screws securing the bottom cover.
Insert the end of an iFixit opening tool or an opening pick into the seam between the bottom and top case to release the clips holding them together.
Slide the opening tool or pick around the edge of the laptop until the case is fully released.
Remove the lower case.
Orient your laptop so that you have access to the bottom cover, with the fan vents facing upwards.
Use a Phillips #00 screwdriver to loosen the eight screws securing the bottom cover.
Insert the end of an iFixit opening tool or opening picks into the seam between the bottom and top case to release the clips holding them together.
Slide the opening tool or pick around the edge of the laptop until it is fully separated.
Remove the bottom cover.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
