Shop the Holiday Gift Guide
Dell Latitude 5580 Battery Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
6
Past 7 Days:
30
Past 30 Days:
161
All Time:
1,382
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your Dell Latitude 5580 is showing signs of a decreased battery life, follow this guide to replace your battery. Your device may experience overheating, physical damage, or slow charging.
 Lithium-ion batteries can often bloat or become faulty with prolonged usage, causing issues with the laptop and requiring replacement. If you have a swollen battery, be very careful. Review this What to do with a swollen battery guide for how to deal with it.
Before you begin this repair, make sure your laptop is powered off and unplugged from the charger.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Dell Latitude 5580 Battery Replacement, Battery: step 1, image 1 of 3 Dell Latitude 5580 Battery Replacement, Battery: step 1, image 2 of 3 Dell Latitude 5580 Battery Replacement, Battery: step 1, image 3 of 3
      • Orient your laptop so that you have access to the bottom cover, with the fan vents facing upwards.
      • Use a Phillips #00 screwdriver to loosen the eight screws securing the bottom cover.
      • They are captive screws and do not fully come out of the holes. Don't force them or you may damage the screws or holes on the bottom case.
      • Insert the end of an iFixit opening tool or opening picks into the seam between the bottom and top case to release the clips holding them together.
      • Slide the opening tool or pick around the edge of the laptop until it is fully separated.
      • Remove the bottom cover.
      Ask FixBot
    2. Dell Latitude 5580 Battery Replacement: step 2, image 1 of 3 Dell Latitude 5580 Battery Replacement: step 2, image 2 of 3 Dell Latitude 5580 Battery Replacement: step 2, image 3 of 3
      • Remove the single Phillips #00 screw that is holding down the battery.
      Ask FixBot
    3. Dell Latitude 5580 Battery Replacement: step 3, image 1 of 2 Dell Latitude 5580 Battery Replacement: step 3, image 2 of 2
      • Use the pull tab to gently pull the battery cable out of its socket.
      Ask FixBot
    4. Dell Latitude 5580 Battery Replacement: step 4, image 1 of 2 Dell Latitude 5580 Battery Replacement: step 4, image 2 of 2
      • Remove the old battery.
      • To install the battery connection cable, push gently into the original connection port to connect the replacement battery to the computer. Tuck in the battery connection cable underneath the plastic frame next to the battery.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
For optimal performance, calibrate your newly installed battery after completing this guide.
Author
with
Jack G Johnson
261 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 30
Past 30 Days: 161
All Time: 1,382
