Dell Latitude 5521 Memory Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
67
All Time:
1,070
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
    1. Dell Latitude 5521 Memory Replacement, Base Cover Removal: step 1, image 1 of 3 Dell Latitude 5521 Memory Replacement, Base Cover Removal: step 1, image 2 of 3 Dell Latitude 5521 Memory Replacement, Base Cover Removal: step 1, image 3 of 3
      • Loosen the 9 captive Phillips #0 screws from the bottom of the case.
      • Carefully pry open the base cover with your spudger. Work your way around the case slowly, being careful not to damage any of the components inside.
      • Once removed you will have access to the contents of your case.
      Ask FixBot
    1. Dell Latitude 5521 Memory Replacement, Memory Removal: step 2, image 1 of 3 Dell Latitude 5521 Memory Replacement, Memory Removal: step 2, image 2 of 3 Dell Latitude 5521 Memory Replacement, Memory Removal: step 2, image 3 of 3
      • Locate Memory on the mainboard.
      • Gently push the retention clips away from the memory module. Once you have both clips pushed away the memory module will "pop-up" on it's own.
      • Pull the memory module away from the mainboard.
      Ask FixBot
Michael Engle
479 Reputation
5 Guides authored
1 Guide Comment
Thanks, this helped me! I noted a few things:
1.some of the screws are a little hard to get out, I think because they have lock-tite, it acts as a retainer. They had to be pulled while also unscrewing.
2.I used the iFixit bladed halberd, to pry of the case without breaking the clips. I know it's not as common of a tool, but the ultra thing blade worked well to disengage the clips gently.
3. My single 16GB DIMM wasn't cutting it. All physical memory was exhausted by the time I booted and loaded one Office file. I added a 4GB PC4-2666MHZ I had lying around, and it worked. Mixing and matching isn't recommended, but it worked in my case. Hopefully now I have some breathing room for running apps. PC/Mac vendors should stop selling units with 16GB or less. It simply isn't enough for a modern Mac or Windows (but does work fine for Linux).
Chris Alleyne-Levy - Reply Share
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 67
All Time: 1,070
