Introduction
Go to step 1 ↓If your display has been cracked or shattered, or you're having issues with your device's display, you may choose to replace it.
Before taking apart your device to replace the display, look through the troubleshooting guides on the Dell Latitude 5500 device page to ensure there isn't an easier solution to your problem.
Removing the display from your device is a somewhat involved process that requires removing the display from the bezel and then disconnecting it from the laptop.
Warning: The screen is fragile, and prone to being scratched. Handle it with care, and place it on a soft surface after removing it.
Tools
Use a Phillips #0 screwdriver to loosen the eight captive screws on the back panel.
With your device right-side up, fully lift up the lid.
Using an opening pick, loosen the double-sided tape connecting the bezel to the display.
Using hands or an opening tool, remove the bezel from your device.
