Shop the Holiday Gift Guide
Dell Latitude 5490 Heatsink Replacement
View statistics:
Past 24 Hours:
9
Past 7 Days:
21
Past 30 Days:
71
All Time:
471
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
The heatsink dissipates heat by directing the heat from the CPU (Central Processing Unit) to the fans, ensuring optimal operating temperatures.
In this guide, we will show you how to install and replace the heatsink in your Dell Latitude 5490 laptop.
If the heatsink is corroded or damaged the entire assembly will need to be replaced. Replacing a broken heatsink will allow your laptop to function without faltering. An operational heatsink protects your laptop against heat related damage and can extend its lifetime.
Tools
    1. Dell Latitude 5490 Heatsink Replacement, Removing Back Panel and Disconnecting Battery: step 1, image 1 of 3 Dell Latitude 5490 Heatsink Replacement, Removing Back Panel and Disconnecting Battery: step 1, image 2 of 3 Dell Latitude 5490 Heatsink Replacement, Removing Back Panel and Disconnecting Battery: step 1, image 3 of 3
      • Power off the laptop before beginning the disassembly process.
      • Close the device and flip the laptop over so the backplate is facing up.
      Ask FixBot
    2. Dell Latitude 5490 Heatsink Replacement: step 2, image 1 of 2 Dell Latitude 5490 Heatsink Replacement: step 2, image 2 of 2
      • Using a Phillips #0 Screwdriver, loosen all eight captive screws in the backplate.
      • You do not need to fully remove the screws. Instead, unscrew them until you can easily jostle the screws.
      Ask FixBot
    3. Dell Latitude 5490 Heatsink Replacement: step 3, image 1 of 2 Dell Latitude 5490 Heatsink Replacement: step 3, image 2 of 2
      • Using the spudger, pry the backplate from the laptop starting from external chassis (the back side of the laptop).
      • Continue prying in a clockwise direction around the backplate until it is able to be removed with just your hands.
      • Remove the backplate and put it aside for reassembly.
      Ask FixBot
    4. Dell Latitude 5490 Heatsink Replacement: step 4, image 1 of 2 Dell Latitude 5490 Heatsink Replacement: step 4, image 2 of 2
      • Using your finger, remove the battery connector using the handle found on top.
      • You do not need to remove the connector completely from the laptop. Doing so may result in damage to your computer. Instead, pull the handle so the connector is suspended above the pins.
      Ask FixBot
    5. Dell Latitude 5490 Heatsink Replacement: step 5, image 1 of 1
      • Hold down the power button for 15 seconds to discharge the remaining electricity within the laptop.
      Ask FixBot
    1. Dell Latitude 5490 Heatsink Replacement, Heatsink: step 6, image 1 of 1
      • Remove the four 7 mm screws from the heatsink using a Phillips #0 screwdriver.
      Ask FixBot
    2. Dell Latitude 5490 Heatsink Replacement: step 7, image 1 of 3 Dell Latitude 5490 Heatsink Replacement: step 7, image 2 of 3 Dell Latitude 5490 Heatsink Replacement: step 7, image 3 of 3
      • Using your fingers, gently pull the heatsink from the CPU.
      Ask FixBot
    3. Dell Latitude 5490 Heatsink Replacement: step 8, image 1 of 2 Dell Latitude 5490 Heatsink Replacement: step 8, image 2 of 2
      • Clean the old thermal paste from the CPU using a lint-free cloth and high-concentration isopropyl alcohol.
      • If you are replacing just the thermal paste and not the entire heatsink, clean the thermal paste from the heatsink.
      • For reassembly, apply a pea-sized amount of thermal paste to the shiny metal part of your CPU, then lightly press the heatsink into place.
      Ask FixBot
Author
with
Jordan
730 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 21
Past 30 Days: 71
All Time: 471
