Dell Latitude 5320 2-in-1 SSD Replacement
  1. Dell Latitude 5320 2-in-1 SSD Replacement, Disconnecting Dell Latitude 5320 2-in-1 Battery: step 1, image 1 of 1
    • Shut down your laptop completely.
    • Unplug the laptop from any charging cables or other connected accessories.
    • Flip the laptop over so the bottom case is facing upward.
    Ask FixBot
  2. Dell Latitude 5320 2-in-1 SSD Replacement: step 2, image 1 of 2 Dell Latitude 5320 2-in-1 SSD Replacement: step 2, image 2 of 2
    • Using a Phillips #000 screwdriver, loosen the eight captive screws that secure the bottom cover.
    • The screws will remain attached to the cover, so do not try to remove them completely. Turn each screw until it spins freely and you feel it no longer tightens.
    Ask FixBot
  3. Dell Latitude 5320 2-in-1 SSD Replacement: step 3, image 1 of 3 Dell Latitude 5320 2-in-1 SSD Replacement: step 3, image 2 of 3 Dell Latitude 5320 2-in-1 SSD Replacement: step 3, image 3 of 3
    • Insert an opening tool into the seam between the bottom cover and the rest of the device.
    • Gently work your way around the edges until the clips release. Lift the cover away and set it aside.
    Ask FixBot
  4. Dell Latitude 5320 2-in-1 SSD Replacement: step 4, image 1 of 3 Dell Latitude 5320 2-in-1 SSD Replacement: step 4, image 2 of 3 Dell Latitude 5320 2-in-1 SSD Replacement: step 4, image 3 of 3
    • Gently lift the battery cable straight up from its socket on the motherboard to disconnect it.
    Ask FixBot
  5. Dell Latitude 5320 2-in-1 SSD Replacement, SSD: step 5, image 1 of 2 Dell Latitude 5320 2-in-1 SSD Replacement, SSD: step 5, image 2 of 2
    • Using a Phillips #000 screwdriver, remove the two 2mm screws holding the SSD cover in place.
    Ask FixBot
  6. Dell Latitude 5320 2-in-1 SSD Replacement: step 6, image 1 of 1
    • Gently lift the cover straight up from its place.
    Ask FixBot
  7. Dell Latitude 5320 2-in-1 SSD Replacement: step 7, image 1 of 2 Dell Latitude 5320 2-in-1 SSD Replacement: step 7, image 2 of 2
    • Use your fingertip to lift the blue plastic retaining bar straight up.
    Ask FixBot
  8. Dell Latitude 5320 2-in-1 SSD Replacement: step 8, image 1 of 2 Dell Latitude 5320 2-in-1 SSD Replacement: step 8, image 2 of 2
    • Holding the edges, gently slide the SSD out of its slot on the motherboard.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 145
