Dell Latitude 5320 2-in-1 Battery Replacement
  1. Dell Latitude 5320 2-in-1 Battery Replacement, Disconnecting Dell Latitude 5320 2-in-1 Battery: step 1, image 1 of 1
    • Shut down your laptop completely.
    • Unplug the laptop from any charging cables or other connected accessories.
    • Flip the laptop over so the bottom case is facing upward.
    Ask FixBot
  2. Dell Latitude 5320 2-in-1 Battery Replacement: step 2, image 1 of 2 Dell Latitude 5320 2-in-1 Battery Replacement: step 2, image 2 of 2
    • Using a Phillips #000 screwdriver, loosen the eight captive screws that secure the bottom cover.
    • The screws will remain attached to the cover, so do not try to remove them completely. Turn each screw until it spins freely and you feel it no longer tightens.
    Ask FixBot
  3. Dell Latitude 5320 2-in-1 Battery Replacement: step 3, image 1 of 3 Dell Latitude 5320 2-in-1 Battery Replacement: step 3, image 2 of 3 Dell Latitude 5320 2-in-1 Battery Replacement: step 3, image 3 of 3
    • Insert an opening tool into the seam between the bottom cover and the rest of the device.
    • Gently work your way around the edges until the clips release. Lift the cover away and set it aside.
    Ask FixBot
  4. Dell Latitude 5320 2-in-1 Battery Replacement: step 4, image 1 of 3 Dell Latitude 5320 2-in-1 Battery Replacement: step 4, image 2 of 3 Dell Latitude 5320 2-in-1 Battery Replacement: step 4, image 3 of 3
    • Gently lift the battery cable straight up from its socket on the motherboard to disconnect it.
    Ask FixBot
  5. Dell Latitude 5320 2-in-1 Battery Replacement, Battery: step 5, image 1 of 2 Dell Latitude 5320 2-in-1 Battery Replacement, Battery: step 5, image 2 of 2
    • Using a Phillips #000 screwdriver, loosen the four captive screws that secure the battery.
    • The screws will remain attached to the battery, so do not try to remove them completely.
    Ask FixBot
  6. Dell Latitude 5320 2-in-1 Battery Replacement: step 6, image 1 of 2 Dell Latitude 5320 2-in-1 Battery Replacement: step 6, image 2 of 2
    • Grasp the battery by the edges and carefully lift the battery out of the device.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 52
All Time: 286
