Introduction
If your SSD is not functioning properly anymore or you are looking to increase your storage space, this guide will show you how to replace your SSD for the Dell Latitude 5289 2-in-1.
Before beginning this repair, make sure to turn off the laptop, undock it if it is connected to a docking device, unplug all cables from the laptop, open the display and press and hold the power button for a few seconds to ground the system board, remove any installed ExpressCards or Smart cards, and remove the MicroSD from the laptop.
Loosen the eight 5 mm captive screws in the base cover using a Phillips #00 screwdriver.
Gently pry the base cover with an opening tool starting from the hinges at the top edge.
Lift the cover off of the laptop.
If there is a thermal bracket, remove the two 3.0 mm screws and lift and slide the thermal bracket away using a Phillips #00 screwdriver.
If there is no thermal bracket, remove the single 3.0 mm screw using a Phillips #00 screwdriver.
Pull the SSD card from the slot.
