Dell Latitude 5289 2-in-1 Fan and Heat Sink Replacement
    1. Dell Latitude 5289 2-in-1 Fan and Heat Sink Replacement, Base Cover: step 1, image 1 of 3 Dell Latitude 5289 2-in-1 Fan and Heat Sink Replacement, Base Cover: step 1, image 2 of 3 Dell Latitude 5289 2-in-1 Fan and Heat Sink Replacement, Base Cover: step 1, image 3 of 3
      • Loosen the eight 5 mm captive screws in the base cover using a Phillips #00 screwdriver.
      • Gently pry the base cover with an opening tool starting from the hinges at the top edge.
      • Lift the cover off of the laptop.
      Ask FixBot
    1. Dell Latitude 5289 2-in-1 Fan and Heat Sink Replacement, Fan and Heat Sink: step 2, image 1 of 3 Dell Latitude 5289 2-in-1 Fan and Heat Sink Replacement, Fan and Heat Sink: step 2, image 2 of 3 Dell Latitude 5289 2-in-1 Fan and Heat Sink Replacement, Fan and Heat Sink: step 2, image 3 of 3
      • Disconnect the fan cable from the computer board.
      • Remove the six 3.0 screws that secure the fan and heat sink to the board using a Phillips #00 screwdriver.
      • Lift the fan and heat sink assembly away from the board.
      Ask FixBot
To reassemble your device, clean the thermal paste from the heat sink off with isopropyl alcohol (90% or higher) and a lint-free cloth or paper towel, reapply a pea size amount of thermal paste on the center of the heat sink, and follow these instructions in reverse order.
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 15
Past 30 Days: 66
All Time: 220
