Dell Latitude 5289 2-in-1 Display Assembly Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
12
Past 30 Days:
66
All Time:
300
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your display assembly is not functioning properly anymore, this guide will show you how to replace your display assembly for the Dell Latitude 5289 2-in-1.
Before beginning this repair, make sure to turn off the laptop, undock it if it is connected to a docking device, unplug all cables from the laptop, open the display and press and hold the power button for a few seconds to ground the system board, remove any installed ExpressCards or Smart cards, and remove the MicroSD from the laptop.
Tools
    1. Dell Latitude 5289 2-in-1 Display Assembly Replacement, Base Cover: step 1, image 1 of 3 Dell Latitude 5289 2-in-1 Display Assembly Replacement, Base Cover: step 1, image 2 of 3 Dell Latitude 5289 2-in-1 Display Assembly Replacement, Base Cover: step 1, image 3 of 3
      • Loosen the eight 5 mm captive screws in the base cover using a Phillips #00 screwdriver.
      • Gently pry the base cover with an opening tool starting from the hinges at the top edge.
      • Lift the cover off of the laptop.
      Ask FixBot
    1. Dell Latitude 5289 2-in-1 Display Assembly Replacement, Display Assembly: step 2, image 1 of 1
      • Lift the ribbon and disconnect the battery cable from the connector on the system board.
      Ask FixBot
    2. Dell Latitude 5289 2-in-1 Display Assembly Replacement: step 3, image 1 of 1
      • Peel the tapes that secure the antenna cables and remove the cables from the routing clips.
      Ask FixBot
    3. Dell Latitude 5289 2-in-1 Display Assembly Replacement: step 4, image 1 of 3 Dell Latitude 5289 2-in-1 Display Assembly Replacement: step 4, image 2 of 3 Dell Latitude 5289 2-in-1 Display Assembly Replacement: step 4, image 3 of 3
      • Disconnect the IR camera and touchscreen cable.
      • Remove the 1.7 mm screws that secure the eDP bracket using a Phillips #00 screwdriver. Lift the bracket away from the computer.
      • Disconnect the G-sensor and eDP cables.
      Ask FixBot
    4. Dell Latitude 5289 2-in-1 Display Assembly Replacement: step 5, image 1 of 3 Dell Latitude 5289 2-in-1 Display Assembly Replacement: step 5, image 2 of 3 Dell Latitude 5289 2-in-1 Display Assembly Replacement: step 5, image 3 of 3
      • Place the base of the computer with the display assembly at 270 degrees.
      • Remove the 4.0 mm screws that secure the display hinge brackets using a Phillips #00 screwdriver.
      • Lift the display assembly away from the computer.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 66
All Time: 300
