Dell Latitude 14 Rugged 5414 Battery Replacement
    1. Dell Latitude 14 Rugged 5414 Battery Replacement, Battery: step 1, image 1 of 3 Dell Latitude 14 Rugged 5414 Battery Replacement, Battery: step 1, image 2 of 3 Dell Latitude 14 Rugged 5414 Battery Replacement, Battery: step 1, image 3 of 3
      • Flip the laptop over so the bottom side is facing up.
      • Use a JIS #1 screwdriver to remove all twenty-one 7 mm screws that secure the bottom cover.
      • Keep screws organized, as their lengths may vary.
      Ask FixBot
    2. Dell Latitude 14 Rugged 5414 Battery Replacement: step 2, image 1 of 2 Dell Latitude 14 Rugged 5414 Battery Replacement: step 2, image 2 of 2
      • Gently slide out the optical disc drive from the underside of the right edge of the laptop.
      • If you’re unable to remove the disc drive, make sure all twenty-one screws have been fully unscrewed.
      Ask FixBot
    3. Dell Latitude 14 Rugged 5414 Battery Replacement: step 3, image 1 of 2 Dell Latitude 14 Rugged 5414 Battery Replacement: step 3, image 2 of 2
      • Lift the bottom cover of the laptop starting from the corner.
      • Insert an opening tool or heavy duty nylon spudger into the seam between the top and bottom case and slide it around the perimeter to release the clips holding it together.
      • Remove the bottom cover.
      Ask FixBot
    4. Dell Latitude 14 Rugged 5414 Battery Replacement: step 4, image 1 of 3 Dell Latitude 14 Rugged 5414 Battery Replacement: step 4, image 2 of 3 Dell Latitude 14 Rugged 5414 Battery Replacement: step 4, image 3 of 3
      • Use a JIS #0 screwdriver to remove the four 4 mm screws securing the battery to the chassis.
      • Use the blue tab to lift the battery from the left edge to access the battery connector on the right edge.
      • Carefully disconnect the battery cable from the motherboard by pulling the connector straight out of the socket.
      • Avoid pulling the connector upward to prevent damage.
      • Once the battery is fully disconnected, lift the battery out of the laptop.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Jaylon James
387 Reputation
3 Guides authored
1 Guide Comment
There's a battery bay door on the end opposite of the HDD caddy; it has a similar removal mechanism [open door, push in blue latch, pull out battery]. That would probably be easier than this.
Ralph L - Reply Share
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 110
All Time: 647
