Dell Inspiron Mini 1012: Keyboard Replacement
  1. Dell Inspiron Mini 1012: Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Remove the battery
  2. Dell Inspiron Mini 1012: Keyboard Replacement: step 2, image 1 of 1
    • Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
  3. Dell Inspiron Mini 1012: Keyboard Replacement: step 3, image 1 of 2 Dell Inspiron Mini 1012: Keyboard Replacement: step 3, image 2 of 2
    • At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown
    • When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
    • Gently lift up the keyboard starting at the top of the frame
    • Make sure that you do not damage the ribbon attached to the bottom of the keyboard
  4. Dell Inspiron Mini 1012: Keyboard Replacement: step 4, image 1 of 1
    • Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
    • Perform steps one through four in reverse order with your new keyboard to finish the replacement process
Finish Line
4 other people completed this guide.
Marie K Bordley
241 Reputation
2 Guides authored
Ohio State, Team 1-1, Buehl Fall 2014 Member of Ohio State, Team 1-1, Buehl Fall 2014
OSU-BUEHL-F14S1G1
4 Members
4 Guides authored
One Comment
After keyboard open, You can change HDD or Memory as you like.
최희욱 - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 3,261
