Dell Inspiron 600M Disk Drive Replacement
  1. Dell Inspiron 600M Disk Drive Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 600M Disk Drive Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 600M Disk Drive Replacement, Battery: step 1, image 3 of 3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600M Disk Drive Replacement, Disk Drive: step 2, image 1 of 1
    • Rotate the computer so that it is upside down and you are facing the rear panel with all the connection ports.
  3. Dell Inspiron 600M Disk Drive Replacement: step 3, image 1 of 3 Dell Inspiron 600M Disk Drive Replacement: step 3, image 2 of 3 Dell Inspiron 600M Disk Drive Replacement: step 3, image 3 of 3
    • Using #00 screwdriver, unscrew locking screw.
    • Push in on button directly beneath screw. A tab should pop out as shown in picture 2.
    • Pull out on tab to remove disk drive.
Eric Johnson
13 Reputation
1 Guide authored
Cal Poly, Team 10-40, Forte Spring 2011 Member of Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Members
8 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 2,970
