Introduction
Before replacing the speakers, we recommend starting out with our troubleshooting guide. If you are still having problems, follow the steps below to replace your speakers.
Remove the two 7.8 mm long screws on the left side of the battery with the Phillips #1 screwdriver.
Tool used on this step:Tweezers$4.99
After battery is removed, locate the left and right speakers.
On the right speaker assembly, remove the pin connector using the tweezers.
