Introduction
This entirety of this teardown is needed to complete all other guides with the exception of the RAM, which can be accessed by only removing the top half of the laptop. All other guide's replacement parts can only be accessed by completing all of these steps first.
Using your thumbs, push out on both side tabs simultaneously. You should hear a soft click and see the battery slightly pop out.
Grab and lift the battery off from the underside of the laptop.
Unscrew one 6.75mm screw on the bottom of the plate using a PH0 tip.
Lift off the back plate and set aside
Carefully flip laptop right side up and open to view the keyboard.
Using a plastic opening tool, pry up on the four tabs holding the keyboard in place. Be careful not to damage the keys on the top of the keyboard. You will know when it has been successfully pried open when you hear four clicks from the top of keyboard.
Gently lift the keyboard out from the rest of the laptop and immediately flip over without damaging the ribbon cable.
Carefully disconnect the ribbon cable by flipping up the tab holding the cable in place by using a plastic opening tool. Set keyboard and ribbon cable aside.
