Introduction
This guide to remove your Dell Inspiron 13-7359 screen. You will need a phillips #0 screwdriver and a small plastic spudger. This guide will require more time and is more difficult than the other replacement guides.
First flip over the laptop to expose the back panel
Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
Unscrew and remove the 2 of the 3mm Phillips head screws holding the hard drive in place.
Unscrew and remove the 2 of the 7mm Phillips head screws holding the cooling fan in place.
Remove the loose wiring from the perimeter of the screen.
Gently separate the LCD screen from the laptop casing.
Hello Austin,
according to the very last step where you separate the screen from the glass/touch-unit: is it possible to take out the screen without any problems? I would have expected that it is fixed to the glass with a kind of glue or anything similar? Someone has told me that separating the lcd from the glass could cause damage to the touchfunctioniality.
thanks
6 other people completed this guide.
One Comment
Hi, I was wondering if there's any possibility of cross compatibility between i7378 and i7359 from dell? My computer is the i7359 but I haven't been able to find a reasonably priced replacement display. Thank you very much! Also, I found this alternate guide suggesting that the screen can be replaced slightly more easily than the manual and this guide suggests, is this process feasible? https://www.insidemylaptop.com/replacing...
