Introduction
This guide shows how to remove and replace a worn out battery for the Dell Inspiron 13-7352 laptop.
Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
Use the plastic opening tool to pry up and loosen the back panel.
Remove the back panel.
Gently remove the battery from the rest of the device.
In the official service manual, they also recommend the following after removing battery.:
"Press and hold the power button for 5 seconds, to ground the system board."
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 other people completed this guide.
3 Comments
Hello,
My Dell Inspiron 13-7352 won't turn on; I was using it when there was power outage and I totally drained the battery and it went off automatically, after the power came back I charged it the whole night but it still totally doesn't turn on. I tried to long-press the power button but nothing happens. I am 99% sure that the reason was using it on battery until the whole charge was gone. Please help!
