Introduction
This guide demonstrates how to disassemble your Dell DJ MP3 player to access and replace the motherboard. Follow the steps in great detail to ensure the success of your repair.
Before you begin, make sure that your device is powered off and it is unplugged from the charger and battery is removed.
Using the metal spudger, carefully slide it under the black rubber bottom to remove it.
Using a Phillips J000 head screw driver, unscrew the 4mm screws placed on the outer corners of the metal plate.
Again, take the metal spudger, placing it under the metal plate to take it off.
Inspect your device and be sure that it matches the device that this guide is disassembling.
Familiarize yourself with the specific design of the device.
