Remove the 7 screws from the back cover with a Phillips #0 screwdriver Once all 7 screws have been removed, you can start to pry apart the back cover with your Plastic Blade or your fingers. Then you can start to separate the back cover from the main chromebook. (See pic)
  • Remove the 7 screws from the back cover with a Phillips #0 screwdriver
  • Once all 7 screws have been removed, you can start to pry apart the back cover with your Plastic Blade or your fingers. Then you can start to separate the back cover from the main chromebook. (See pic)
Black Friday
Broken doesn't stand a chance.
Remove the 3 battery screws with a phillips #00 screwdriver.
  • Remove the 3 battery screws with a phillips #00 screwdriver.
  • Remove the battery from the motherboard extension connector
Jon
1,258 Reputation
11 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 101
All Time: 403
