• Open the chromebook until its completely flat on the table
  • Remove both the left and right hinge caps
  • Remove a total of 4 screws. One in each corner.
  • Use a plastic pry tool or blade and start in the top left corner or first left plastic ridge.
  • Lift up the LCD screen from within the LCD assembly frame.
  • On the back of the LCD screen, remove the tape and LCD connector
  • Attach the LCD connector
  • re-apply the tape to the LCD connector
  • Set the new LCD screen into the LCD assembly frame while matching up the screw ports in each corner
  • When installing the LCD bezel, look for the plastic hinge outlines on each side and match them up with the metal hinges on the chromebook.
  • Snap the LCD bezel in place until it is flush with the entire LCD assembly
Jon
1,058 Reputation
11 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 64
All Time: 159
