Fix Your Stuff
Right to Repair
Parts & Tools
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
The battery is a very common part to need to replace on a computer, especially as it becomes older. This is a very straightforward process and will only require removing a few screws and unplugging a cable. It should only take a couple of minutes, and there is little damage to be done.
  1. Set your laptop upside down on your work space.
    • Set your laptop upside down on your work space.
  2. Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
    • Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
  3. Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
    • Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
    • These screws will stay attached to the back cover, so just loosen them until they rattle around.
  4. Using a plastic opening tool, begin to separate the back cover from the body of the computer.
    • Using a plastic opening tool, begin to separate the back cover from the body of the computer.
    • If you have trouble prying a particular part of the back cover off, make sure that the nearest screws are fully loosened.
  5. Using your hands, pull the back cover fully off of the body of the computer.
    • Using your hands, pull the back cover fully off of the body of the computer.
  6. Unplug the battery from the motherboard by gently pulling the black cable header from the motherboard towards the battery. You can locate this cable by checking that its other end connects to the battery. It has black protective wrap.
    • Unplug the battery from the motherboard by gently pulling the black cable header from the motherboard towards the battery.
    • You can locate this cable by checking that its other end connects to the battery. It has black protective wrap.
  7. Using a Phillips #0 screwdriver, remove each of the three 3mm screws from the battery.
    • Using a Phillips #0 screwdriver, remove each of the three 3mm screws from the battery.
  8. Lift the battery away from the computer to remove it.
    • Lift the battery away from the computer to remove it.
    • If there is any resistance to the battery being removed, make sure that all of the screws have been properly removed and that nothing is blocking the battery.
Devon Paul
871 Reputation
6 Guides authored
Cal Poly, Team S22-G1, Livingston Spring 2017 Member of Cal Poly, Team S22-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G1
4 Members
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 64
All Time: 2,575
