Dell Adamo XPS Bridge Battery Replacement
      • Turn off the laptop before doing anything to the laptop.
      • Then turn the laptop around on its back.
      Ask FixBot
      • On the back of the computer there is a latch that you have to slide and hold in order to remove the battery.
      • Then you have to push the computer battery towards the computer and rotate upwards.
      • Finally lift the battery out of the computer.
      Ask FixBot
      • Turn the computer around and remove the eighteen screws on the base cover.
      • The screws that secure the base cover are of different sizes. Note the location and size of the screws as you remove them so that you can replace them correctly
      Ask FixBot
      • You aren't actually taking apart the display but only opening it up to gain access to the palm rest panel and keyboard.
      Ask FixBot
      • Use your fingers to ease the palm rest assembly from the computer.
      • Pull on the plastic tab on top of the cables to avoid damaging the connectors.
      • Exercise extreme care while lifting the palm rest assembly to avoid damaging the function key cable.
      Ask FixBot
      • Lift the palm rest assembly to access the function key cable.
      • To prevent damage to the function key cable, do not disconnect the function key cable from the palm rest.
      Ask FixBot
      • Disconnect the function key cable from the connector on the system board.
      Ask FixBot
      • Lift the connector latch that secures the touch pad cable to the touch pad connector and remove the cable.
      • To prevent damage to the display hinges, ensure that you do not adjust the angle between the display and the computer base after removing the palm rest assembly.
      Ask FixBot
      • Lift the palm rest assembly off the computer base.
      Ask FixBot
      • After removing the laptop battery and the pal rest panel.
      • Disconnect the bridge battery cable from the connector on the left daughter board.
      • Be careful prying out the bridge battery.
      • The bridge battery is glued to the base cover. Use the spudger to pry the bridge battery out of the base cover.
      Ask FixBot
      • Use adhesive on the bridge battery to ahere it to the base cover.
      • Reconnect the bridge battery cable to the connector on the left daughter board.
      Ask FixBot
Christopher Melo-Pelaez
2,090 Reputation
9 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 96
All Time: 843
