DeWalt D28110 Power Switch Replacement
  1. DeWalt D28110 Power Switch Replacement, Disassembling DeWalt D28110 Gear Case: step 1, image 1 of 1
    • Using the T-15 screwdriver, remove the four 22-mm torx screws on the gear case.
    • Unplug the grinder before any disassembly.
  2. DeWalt D28110 Power Switch Replacement: step 2, image 1 of 2 DeWalt D28110 Power Switch Replacement: step 2, image 2 of 2
    • Pull out the gear case.
  3. DeWalt D28110 Power Switch Replacement, Disassembling DeWalt D28110 Back Panel Disassembly: step 3, image 1 of 1
    • Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
  4. DeWalt D28110 Power Switch Replacement: step 4, image 1 of 1
    • Use the edge of the spudger to loosen and remove the back panel.
  5. DeWalt D28110 Power Switch Replacement: step 5, image 1 of 1
    • Remove the single 20-mm torx screw holding the rear panel in place.
  6. DeWalt D28110 Power Switch Replacement: step 6, image 1 of 1
    • Pull back the rear side of the back panel.
  7. DeWalt D28110 Power Switch Replacement, Power Switch: step 7, image 1 of 3 DeWalt D28110 Power Switch Replacement, Power Switch: step 7, image 2 of 3 DeWalt D28110 Power Switch Replacement, Power Switch: step 7, image 3 of 3
    • There is an inner plastic guard behind the motor shaft.
    • Unscrew the four screws at each corner.
    • The guard should pull out with a good firm tug.
  8. DeWalt D28110 Power Switch Replacement: step 8, image 1 of 3 DeWalt D28110 Power Switch Replacement: step 8, image 2 of 3 DeWalt D28110 Power Switch Replacement: step 8, image 3 of 3
    • Just behind the inner guard is the button slide.
    • Use needle nose pliers to pinch and push the button's flanges together, and out of the slot.
  9. DeWalt D28110 Power Switch Replacement: step 9, image 1 of 3 DeWalt D28110 Power Switch Replacement: step 9, image 2 of 3 DeWalt D28110 Power Switch Replacement: step 9, image 3 of 3
    • Using the J-1 screwdriver, unscrew the power cord wires from the red switch box (located in the back of the grinder).
  10. DeWalt D28110 Power Switch Replacement: step 10, image 1 of 2 DeWalt D28110 Power Switch Replacement: step 10, image 2 of 2
    • Disconnect the motor wires from the other side of the switch box.
    • They wires are connected as a sleeve to the flat pin out of the switch box. A firm pull should do it.
3 other people completed this guide.
Kean Wee
495 Reputation
4 Guides authored
Cal Poly, Team 18-6, Maness Winter 2015 Member of Cal Poly, Team 18-6, Maness Winter 2015
CPSU-MANESS-W15S18G6
5 Members
7 Guides authored
One Comment
Very clear and concise guide with relevent pictures. Very well done, thank you
Michael Creel - Reply
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 34
All Time: 5,607
