DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation
  1. DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation, Preparations: step 1, image 1 of 1
    • Pull the plug!
    • Remove the drip tray, the water tank and the pulp container.
  2. DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation, Unscrew the rear panel: step 2, image 1 of 2 DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation, Unscrew the rear panel: step 2, image 2 of 2
    • The rear panel and side panels are attached with six phillips screws #2. Screw them out.
  3. DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation, Remove right side panel: step 3, image 1 of 2 DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation, Remove right side panel: step 3, image 2 of 2
    • Slide the right side panel about 2 cm to the back.
    • Then solve it.
  4. DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation, Remove left side panel: step 4, image 1 of 3 DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation, Remove left side panel: step 4, image 2 of 3 DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation, Remove left side panel: step 4, image 3 of 3
    • The left side is a bit stuck. Place a plastic opening tool in the gap between the front and left side panel above the opening for the water tank. Lift the gap slightly larger.
    • Then place the tool in the gap between the front and left side panel under the opening for the water tank. Increase the gap and push the side part about 2 cm to the rear.
    • Lift out the left side piece.
  5. DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation, Remove rear panel: step 5, image 1 of 1
    • Take out the rear panel.
  6. DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation, Unscrew top cover: step 6, image 1 of 3 DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation, Unscrew top cover: step 6, image 2 of 3 DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation, Unscrew top cover: step 6, image 3 of 3
    • The front panel is secured with four PH2 Phillips screws, two left and one right each. Turn it out.
    • Use a plastic opening tool to lever off the steam tap.
    • Carefully pull the front panel about 1 cm forward so that there is a gap between the top cover and the front panel,
    • Do not pull the front panel too far, it is still attached with different hoses and cables.
  7. DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation, Remove top cover: step 7, image 1 of 3 DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation, Remove top cover: step 7, image 2 of 3 DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation, Remove top cover: step 7, image 3 of 3
    • Two Phillips screws PH2 hold the lid at the back. Turn it out.
    • Lift the lid upwards.
  8. DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation, pressure regulator: step 8, image 1 of 2 DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation, pressure regulator: step 8, image 2 of 2
    • The old safety valve - seen in the first photo already expanded - is screwed on the pump. It is replaced by a combination of safety valve and pressure balance valve. The diaphragm valve dampens the shocks of the pump, making the flow of water quieter and quieter.
  9. DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation: step 9, image 1 of 2 DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation: step 9, image 2 of 2
    • Remove the two hoses from the valve. For the thicker hose you have to squeeze the hose clamp with pliers, push it away and you can pull off the hose.
    • With the thinner pressure hose above you have to pull out first a clamp, then the hose comes out easily. There may be a gasket on the hose or it may stick in the valve.
  10. DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation: step 10, image 1 of 1
    • Pull the pump slightly out of the housing in its rubber mount. Place a fork wrench SW 12 on the pump tube.
    • Then turn out the old valve.
  11. DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation: step 11, image 1 of 2 DeLonghi ESAM xxxx - (Different Types) Pressure Regulator Installation: step 11, image 2 of 2
    • Make sure that there is a sealing ring above the thread on the valves, marked yellow in the photo.
    • First screw the safety valve into the pump tube. Do not turn too hard.
    • then screw the pressure regulating valve into the safety valve.
    • Place the two outputs on top of each other.
    • Put the two hoses back on. Also pay attention here to the thinner tube on the sealing ring, if possible, a new one.
Repeat the steps in order to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
202,272 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,102 Guides authored
2 Comments
Sehr gute Anleitung.
Den Deckel abzunehmen fand ich nicht notwendig.
Sehr hilfreich die Ersatzteil Bezugsquellen.
Maschine ist jetzt um einiges leiser.
Danke
SCHLUMPF - Reply
Gern geschehen. Stimmt, bei dieser Reparatur muss der Deckel nicht unbedingt ab, liegt halt an der Logik dieser aufeinander aufbauenden Anleitungen.
VauWeh - Reply
Past 24 Hours: 7
Past 7 Days: 14
Past 30 Days: 51
All Time: 3,307
