Firmly press the cartridge release button with your finger.
You may need to hold the cassette and/or entire device still while pressing the button.
Lift the label tape cassette out of the device.
Use Phillips #00 screwdriver to remove three screws
Remove blade cutter
Use Phillips #00 screwdriver to remove remaining two screws from the battery compartment
Use Phillips #00 screwdriver to remove six screws
Slowly separate back panel
Gently pull rubber transport roller up to remove
Replace rubber transport roller
