DOSS SoundBox Motherboard Replacement
  1. DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: step 1, image 1 of 3 DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: step 1, image 2 of 3 DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: step 1, image 3 of 3
    • Use a small plastic opening tool to gently lift the side of the grille.
    • Gently slide the tool to the front of the speaker.
    • Repeat the process on the bottom of the grille.
    • Gently pull the grille off of the speaker enclosure.
    • Pry with caution, for the grille is fragile.
  2. DOSS SoundBox Motherboard Replacement, Speaker: step 2, image 1 of 2 DOSS SoundBox Motherboard Replacement, Speaker: step 2, image 2 of 2
    • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
    • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
    • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
    • Using a Magnetic Mat throughout this process will help prevent losing screws.
  3. DOSS SoundBox Motherboard Replacement: step 3, image 1 of 2 DOSS SoundBox Motherboard Replacement: step 3, image 2 of 2
    • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
  4. DOSS SoundBox Motherboard Replacement: step 4, image 1 of 2 DOSS SoundBox Motherboard Replacement: step 4, image 2 of 2
    • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
    • The speakers are ready to be removed and replaced.
    • Ensure that the device is turned off when handling bare wire.
    • Soldering iron is very hot.
  5. DOSS SoundBox Motherboard Replacement, Battery: step 5, image 1 of 2 DOSS SoundBox Motherboard Replacement, Battery: step 5, image 2 of 2
    • Use a JIS #00 screwdriver to remove the four 3/32" screws that attach the base-plate to the speaker enclosure.
    • Use a magnetic mat to prevent the loss of screws.
  6. DOSS SoundBox Motherboard Replacement: step 6, image 1 of 2 DOSS SoundBox Motherboard Replacement: step 6, image 2 of 2
    • Use a JIS #1 screwdriver to remove the six 3/32" screws marked with a red circle.
    • Remove the two 1/16" screws marked with orange circles using a JIS #000 screwdriver.
  7. DOSS SoundBox Motherboard Replacement: step 7, image 1 of 1
    • Remove the six 3/32" screws marked with red circles using a JIS #00 screwdriver.
    • Remove the larger 3/32" screw indicated by an orange circle using a JIS #1 screwdriver.
    • Once the screws are removed, gently lift the top (where the touch controls are) off of the speaker.
  8. DOSS SoundBox Motherboard Replacement: step 8, image 1 of 1
    • De-solder the connections from the battery to the circuit board.
    • If you do not already have a replacement battery, you can purchase one here.
  9. DOSS SoundBox Motherboard Replacement, Motherboard: step 9, image 1 of 1
    • Follow the steps leading up to the actual battery removal, but do not actually remove the battery.
    • Remove the two 3/32" screws that attach the motherboard to the battery compartment using a JIS #00 screwdriver.
    • Use your fingers or a pair of tweezers to remove the clip holding the ribbon connector in place. The connector is indicated with an orange marker.
    • Be sure not to apply excessive force on the ribbon connector, as it can break.
    • Find the speaker connector, indicated by a yellow circle, and using your fingers disconnect it.
  10. DOSS SoundBox Motherboard Replacement: step 10, image 1 of 2 DOSS SoundBox Motherboard Replacement: step 10, image 2 of 2
    • Locate and remove the two 3/32" screws, indicated by red markers, that fix the motherboard to the speaker enclosure.
  11. DOSS SoundBox Motherboard Replacement: step 11, image 1 of 3 DOSS SoundBox Motherboard Replacement: step 11, image 2 of 3 DOSS SoundBox Motherboard Replacement: step 11, image 3 of 3
    • Using the plastic opening tool, gently begin to pry the circuit card away from the speaker enclosure.
    • There is adhesive on the top of the motherboard, use caution while prying to avoid breakage.
    • Using your fingers, you can now remove the motherboard.
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 56
All Time: 4,732
