Fix Your Stuff
Right to Repair
Parts & Tools
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
For this project you will need to have the knowledge, and tools necessary to solder. The following link gives instructions on how to solder. How To Solder and Desolder Connections
Parts
No parts specified.
  1. Take plastic opening tools, and find a spot on the back of tablet to lift the back plate. Once back is lifted enough, remove the back of the tablet carefully with fingers Take plastic opening tools, and find a spot on the back of tablet to lift the back plate. Once back is lifted enough, remove the back of the tablet carefully with fingers Take plastic opening tools, and find a spot on the back of tablet to lift the back plate. Once back is lifted enough, remove the back of the tablet carefully with fingers
    • Take plastic opening tools, and find a spot on the back of tablet to lift the back plate. Once back is lifted enough, remove the back of the tablet carefully with fingers
  2. Locate battery, and examine wires connected to battery.
    • Locate battery, and examine wires connected to battery.
  3. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  4. Carefully remove battery without putting any strain on connected wires. The battery is held to the tablet with adhesive, so be careful not to jerk the battery when it becomes loose. Carefully remove battery without putting any strain on connected wires. The battery is held to the tablet with adhesive, so be careful not to jerk the battery when it becomes loose. Carefully remove battery without putting any strain on connected wires. The battery is held to the tablet with adhesive, so be careful not to jerk the battery when it becomes loose.
    • Carefully remove battery without putting any strain on connected wires. The battery is held to the tablet with adhesive, so be careful not to jerk the battery when it becomes loose.
  5. Use a soldering iron to carefully remove wires from motherboard. Then remove battery. Use a soldering iron to carefully remove wires from motherboard. Then remove battery. Use a soldering iron to carefully remove wires from motherboard. Then remove battery.
    • Use a soldering iron to carefully remove wires from motherboard. Then remove battery.
Kaitlyn Hayes
414 Reputation
4 Guides authored
USF Tampa, Team 5-2, Brown Winter 2015 Member of USF Tampa, Team 5-2, Brown Winter 2015
USFT-BROWN-W15S5G2
4 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 1,402
