DJI Phantom 3 Advanced Landing Gear Replacement
  1. DJI Phantom 3 Advanced Landing Gear Replacement, Battery: step 1, image 1 of 2 DJI Phantom 3 Advanced Landing Gear Replacement, Battery: step 1, image 2 of 2
    • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
    • Remember to disarm and power down your quadcopter before beginning any disassembly.
  2. DJI Phantom 3 Advanced Landing Gear Replacement: step 2, image 1 of 2 DJI Phantom 3 Advanced Landing Gear Replacement: step 2, image 2 of 2
    • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
    • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
  3. DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: step 3, image 1 of 3 DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: step 3, image 2 of 3 DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: step 3, image 3 of 3
    • Turn the phantom upside down.
    • Remove the eight 7.5mm long 3mm screws, securing the landing gear to the body of the quadcopter, with a T-8 screwdriver.
  4. DJI Phantom 3 Advanced Landing Gear Replacement: step 4, image 1 of 3 DJI Phantom 3 Advanced Landing Gear Replacement: step 4, image 2 of 3 DJI Phantom 3 Advanced Landing Gear Replacement: step 4, image 3 of 3
    • Remove the rubber spacer in the landing gear by pushing the spacer out of the slot with your finger.
  5. DJI Phantom 3 Advanced Landing Gear Replacement: step 5, image 1 of 3 DJI Phantom 3 Advanced Landing Gear Replacement: step 5, image 2 of 3 DJI Phantom 3 Advanced Landing Gear Replacement: step 5, image 3 of 3
    • Using a plastic opening tool, carefully separate the two pieces of plastic of the landing gear.
    • Be careful not to break the wire attached, as this is your receiver antenna.
  6. DJI Phantom 3 Advanced Landing Gear Replacement: step 6, image 1 of 3 DJI Phantom 3 Advanced Landing Gear Replacement: step 6, image 2 of 3 DJI Phantom 3 Advanced Landing Gear Replacement: step 6, image 3 of 3
    • Feed the wire and attached plastic through the hole in the landing gear.
7 other people completed this guide.
Quinn Tirpak
319 Reputation
2 Guides authored
Cal Poly, Team 10-2, Livingston Fall 2016 Member of Cal Poly, Team 10-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G2
3 Members
12 Guides authored
One Comment
I have a single coax cable in my landing gear. the gear broke and the wire tore off the connector. How do I fix this?
Art - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 3,795
