Introduction
Did your drone take an unexpected swim in a lake, river, or the ocean? This comprehensive step-by-step guide will walk you through everything you need to know to repair a water-damaged drone and maximize your chances of a full recovery.
In this tutorial, we cover the critical first steps, like immediately removing the battery, and explain the crucial differences between freshwater and highly corrosive saltwater damage. Learn why you should NEVER put your drone in rice or use a hairdryer, and discover the correct way to disassemble and clean your drone's internal components.
Our guide shows you how to inspect the motherboard for oxidation, safely remove shield plates, and clean the electronics using isopropyl alcohol. For severe corrosion from saltwater, we even demonstrate how to use white vinegar as a neutralizing agent. We cover everything from cleaning to reassembly, including applying the correct thermal gel for your drone.
Whether you have a DJI Mini 2, these repair principles apply. Don't let water damage be the end of your drone!
Disclaimer: Disassembling your drone will likely void your warranty. If your drone is still under warranty, contact the manufacturer's support team before attempting a DIY repair.
Video Instructions
0 Guide Comments
