Introduction
This is the chip ID for DJI's Mavic 3 Pro. You can find the full teardown of the Mavic 3 Pro here.
Likely Leadcore H6MN applications processor
Likely Leadcore E2B video processor
Likely Leadcore P1 applications & baseband processor
SK Hynix H9HCNNNBKMMLXR-NEE 2 GB LPDDR4X SDRAM memory
SK Hynix H54G38AYRBX259 1 GB LPDDR4 SDRAM memory
Texas Instruments BQ24179 buck-boost battery charger
Richtek RT1715 USB Type-C power delivery controller
Texas Instruments CDCI6214 four-output clock generator
Texas Instruments LP8758A2 power management
Texas Instruments LM61460AANRJRR 6 A step-down converter
SG Micro SGM61030A 3 A synchronous buck converter
Silergy SY8089A1 2 A synchronous step-down converter
Silicon Content Technology SCT2401FTVBR 600 mA synchronous step-down DC-DC converter
SG Micro SGM3157 SPDT analog switch
HDSC HC32F176KATA-LQ64 32-bit ARM Cortex-M0+ microcontroller
Samsung KLMAG1JETD-B041 16 GB eMMC 5.1 NAND flash memory
Samsung KLM8G1GETF-B041 8 GB eMMC 5.1 NAND flash memory
Samsung K4A4G165WF-BCTD 512 MB DDR4 SDRAM memory
Qorvo ACT8846QM power management
Texas Instruments CDC3RL02 dual channel clock buffer
DIOO DIO3340QN18 USB SuperSpeed 11 Gbps analog switch
Richtek RT5715 2 A synchronous step-down converter
Silergy SY6287CDEC power distribution switch
SG Micro SGM2566A 6 A load switch
Joulwatt ideal diode controller (likely)
3Peak TP181A1-CR bidirectional current sense amplifier
Likely Leadcore IE1000 RF transceiver
Skyworks SKY85743-21 5 GHz WLAN front-end module
Skyworks SKY85331-11 2.4 GHz WLAN front-end module
Synaptics SYN43752A2XKUBG single-chip WiFi 802.11ax w/ Bluetooth 5.1 & FM receiver
Likely Maxscend MXD8730 SP3T RF switch
Likely Maxscend MXD8622E SPDT RF switch
TDK-InvenSense ICM-40609-D 6-axis MEMS accelerometer & gyroscope
SG Micro SGM3204 200 mA charge pump voltage inverter
SG Micro SGM2209-ADJ - 500 mA / - Adj LDO regulator
GLF Integrated Power GLF1121H load switch
Likely Leadcore ADS-B ADS-B receiver
u-blox UBX-M10050-KB GNSS receiver
Maxscend MXDLN16TP GNSS LNA
Nexperia 74LVC1G08 single AND gate
