Introduction
This guide will show how to take apart a D-Link DCS 936L Wi-Fi security camera and remove the motherboard using an opening tool and a Philips 00 screwdriver. There are not many loose pieces making this a quick process as long as you're careful.
Place the camera upwards between your thumb and first finger.
Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
One Comment
Where can I get the replacement motherboard? Been trying to search online, but to no avail.
