Cuisinart-140BK Knob Replacement
  1. Cuisinart-140BK Knob Replacement, Circuit Board: step 1, image 1 of 1
    • Unplug the toaster before disassembly.
  2. Cuisinart-140BK Knob Replacement: step 2, image 1 of 2 Cuisinart-140BK Knob Replacement: step 2, image 2 of 2
    • Turn the toaster upside down.
    • Unscrew all 4mm screws using Phillips #2 screwdriver.
  3. Cuisinart-140BK Knob Replacement: step 3, image 1 of 1
    • Turn the toaster right side up.
    • Lift up the front cover carefully because the cables can be damaged.
    • Pull out the toaster lever knobs by pulling it away from the toaster before removing the top cover.
  4. Cuisinart-140BK Knob Replacement: step 4, image 1 of 3 Cuisinart-140BK Knob Replacement: step 4, image 2 of 3 Cuisinart-140BK Knob Replacement: step 4, image 3 of 3
    • Detach the cable that connects the toaster to the circuit board, in both control panels.
  5. Cuisinart-140BK Knob Replacement: step 5, image 1 of 1
    • Carefully lift up the top cover.
  6. Cuisinart-140BK Knob Replacement: step 6, image 1 of 3 Cuisinart-140BK Knob Replacement: step 6, image 2 of 3 Cuisinart-140BK Knob Replacement: step 6, image 3 of 3
    • The circuit board is located inside the front cover.
    • Unscrew total of six 4mm screws that attach each circuit board to the top cover, using Phillips #2 screwdriver.
    • Remove and replace the circuit board.
  7. Cuisinart-140BK Knob Replacement, Knob: step 7, image 1 of 2 Cuisinart-140BK Knob Replacement, Knob: step 7, image 2 of 2
    • Lift the clear plastic backing off the knob, under the circuit board.
  8. Cuisinart-140BK Knob Replacement: step 8, image 1 of 2 Cuisinart-140BK Knob Replacement: step 8, image 2 of 2
    • Pinch the back side of the knob to detach it from the toaster.
  9. Cuisinart-140BK Knob Replacement: step 9, image 1 of 2 Cuisinart-140BK Knob Replacement: step 9, image 2 of 2
    • This is how the device should look without the knob.
    • Repeat the process on the opposite side of the toaster to remove the second knob.
Alora Saxton
3 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 1,338
