Creality Ender 3 Pro Printing Head Cooling Replacement with mini Satsana
  1. Creality Ender 3 Pro Printing Head Cooling Replacement with mini Satsana, Removing the original head frame: step 1, image 1 of 3 Creality Ender 3 Pro Printing Head Cooling Replacement with mini Satsana, Removing the original head frame: step 1, image 2 of 3 Creality Ender 3 Pro Printing Head Cooling Replacement with mini Satsana, Removing the original head frame: step 1, image 3 of 3
    • Unplug your printer from power.
    • Remove two smaller bolts, mine were screwed tightly, so I had to take a grippy driver, not a "precision" one. These are Torx 8.
    • From the side, remove four bolts holding the fan. Two top bolts are short, two bottom are long. These are Torx 6.
    • I feel safer if my bolts are saved from running like this (not needed if you use any storage or magnetic pad)
    Ask FixBot
  2. Creality Ender 3 Pro Printing Head Cooling Replacement with mini Satsana, Removing cooler from case: step 2, image 1 of 3 Creality Ender 3 Pro Printing Head Cooling Replacement with mini Satsana, Removing cooler from case: step 2, image 2 of 3 Creality Ender 3 Pro Printing Head Cooling Replacement with mini Satsana, Removing cooler from case: step 2, image 3 of 3
    • Four more screws are holding the head cooler from the inside.
    • Halfway through. The original one does not look very impressive, innit?
    • Naked printing head looks like this, yep. Since we are already here, why not give the coolers a clean? Mine were nasty, cats, filament debris, and dust.
    Ask FixBot
  3. Creality Ender 3 Pro Printing Head Cooling Replacement with mini Satsana, Getting our s...tuff together!: step 3, image 1 of 2 Creality Ender 3 Pro Printing Head Cooling Replacement with mini Satsana, Getting our s...tuff together!: step 3, image 2 of 2
    • Fix down your bigger cooler. Notice, the sticker was facing to hotend, so we put it the same way -- the sticker goes to the hotend.
    • The smaller one, from the side, goes to the side, no turning or twisting required. (Don't forget to throw out the small duct that was on the bottom of the side cooler)
    Ask FixBot
  4. Creality Ender 3 Pro Printing Head Cooling Replacement with mini Satsana, Putting the frame back: step 4, image 1 of 2 Creality Ender 3 Pro Printing Head Cooling Replacement with mini Satsana, Putting the frame back: step 4, image 2 of 2
    • Screw back Torx 8.
    • DON'T DO THIS, IF YOU HAVE A SUITABLE SCREWDRIVER!!! I don't have a driver small enough to get to the second screw, so I just put it from the back. Not like it hold a lot, but it kinda restrains a frame from moving around. (I'll fix it next time, maybe better screwdriver\key, or longer bolt with nut?)
    Ask FixBot
Try to print something with your new mini Satsana!
sonickrnd
302 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 181
