Corsair Void Pro RGB Speakers Replacement
  1. Corsair Void Pro RGB Speakers Replacement, Earcup: step 1, image 1 of 1
    • Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
  2. Corsair Void Pro RGB Speakers Replacement: step 2, image 1 of 2 Corsair Void Pro RGB Speakers Replacement: step 2, image 2 of 2
    • Using the Phillips #0 screwdriver, unscrew the seven 6.4 mm screws holding the black speaker cover in place.
    • If you are disassembling the lefthand earfmuff, there will be eight 6.4 mm screws to remove.
  3. Corsair Void Pro RGB Speakers Replacement: step 3, image 1 of 2 Corsair Void Pro RGB Speakers Replacement: step 3, image 2 of 2
    • Remove and set aside the black panel, taking care to keep the wires attached.
    • The panel should lift up without much force. If the panel does not budge, carefully use the iFixit plastic opening tool to dislodge the piece.
  4. Corsair Void Pro RGB Speakers Replacement, Speakers: step 4, image 1 of 1
    • Desolder the wire that connects to the speaker.
    • For steps on how to solder, see this helpful guide.
  5. Corsair Void Pro RGB Speakers Replacement: step 5, image 1 of 2 Corsair Void Pro RGB Speakers Replacement: step 5, image 2 of 2
    • Use a knife tool as a wedge to remove the speaker and glue in the new speaker.
4 other people completed this guide.
Gianna Nobili
827 Reputation
5 Guides authored
Cal Poly, Team S9-G13, Maness Spring 2019 Member of Cal Poly, Team S9-G13, Maness Spring 2019
CPSU-MANESS-S19S9G13
4 Members
14 Guides authored
5 Comments
Where can i find a new speaker ?
brunodehulster - Reply
The speaker listed in the parts, is not the correct speaker. I purchased them and they are NOT a fit.
ksmith - Reply
Whats the size of the speaker?
smack2k - Reply
The size of the speaker is 50 mm and about 10 mm in depth. I used this speaker in my own repair and it worked well.
noahoryan -
Can u show how to change “Charging Port”??
Jason HKB - Reply
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 33
All Time: 3,480
