You're viewing a previously published version of this guide.  View latest version
Older Newer
Parts
No parts specified.
  1. Slide battery latch to left Simultaneously lift battery
    • Slide battery latch to left
    • Simultaneously lift battery
  2. Lift and remove battery Lift and remove battery Lift and remove battery
    • Lift and remove battery
  3. Remove 3x M2.5x4mm Remove 3x M2.5x4mm
    • Remove 3x M2.5x4mm
  4. Lift the keyboard in the middle with a spudger Remove 4 clips by bending keyboard in middle, do not force the clips at the sides Do not remove the keyboard fully, it is attached via a ribbon cable
    • Lift the keyboard in the middle with a spudger
    • Remove 4 clips by bending keyboard in middle, do not force the clips at the sides
    • Do not remove the keyboard fully, it is attached via a ribbon cable
  5. Lift keyboard slightly Push each side of ribbon cable connector Fully remove keyboard
    • Lift keyboard slightly
    • Push each side of ribbon cable connector
    • Fully remove keyboard
Mike B
1,018 Reputation
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 67
