Community-Contributed Guide
Introduction
Go to step 1 ↓If water or coffee ends up in the capsule drawer instead of in the cup, you need to check the brewing unit. A thorough cleaning will probably suffice.
Tools
Remove all attachments such as the water tank, milk tank, and capsule drawers.
Turn the device over so that the back is facing you.
Remove the four Phillips screws.
Remove the back cover; it may be a little stuck.
Pull the right side panel back by about 1cm and remove it
The top cover is secured with a Phillips screw under the side panel. Unscrew that screw.
Push the cap behind the lever for the brewing unit back about 1 cm and remove it.
Bend the two tabs on the sides of the connector to the side using a small flat screwdriver.
Use a suitable tool, e.g., small needle-nose pliers. Be extremely careful when pulling the connector toward you. Work slowly and patiently.
Pull out the metal clamp on the pressure hose to the brewing unit using needle nose pliers
Pull out the pressure hose
Release the two tabs on the sides of the coffee spout.
Remove the coffee spout. It is likely to be stuck, so you may need to use a suitable tool to gently pry it loose
Follow the steps in reverse order to reassemble your device.
5 other people completed this guide.
Special thanks to these translators:
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
1 Guide Comment
Sehr gute Anleitung. Hat mir eine Menge rätseln erspart. Am Ende war die Pyramidenplatte ziemlich verkrustet. Alles gereinigt und funktioniert wieder wie neu.
Danke!
