Cisco Aironet 1242 Dissasembly
  1. Cisco Aironet 1242 Dissasembly, Remove the screws: step 1, image 1 of 2 Cisco Aironet 1242 Dissasembly, Remove the screws: step 1, image 2 of 2
    • The equipment cover is held by 4 screws.
  2. Cisco Aironet 1242 Dissasembly, Removing the cover: step 2, image 1 of 1
    • Once the 4 screws are removed, push to the side to remove the cover.
  3. Cisco Aironet 1242 Dissasembly, Disassembling the main board: step 3, image 1 of 3 Cisco Aironet 1242 Dissasembly, Disassembling the main board: step 3, image 2 of 3 Cisco Aironet 1242 Dissasembly, Disassembling the main board: step 3, image 3 of 3
    • The card is attached to the bottom plate by 4 screws
    • Before removing the logic board, disconnect the antenna cables in both parts of the device.
    • There is a total of 4 cables. Use a tweezer or a spudger to disconnect them.
  4. Cisco Aironet 1242 Dissasembly, Device disassembled: step 4, image 1 of 3 Cisco Aironet 1242 Dissasembly, Device disassembled: step 4, image 2 of 3 Cisco Aironet 1242 Dissasembly, Device disassembled: step 4, image 3 of 3
    • Write the wisdom here.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Attached Documents
Eneider Colina
2,362 Reputation
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 1,053
