Choosing the Right Screwdriver Bit
  1. Choosing the Right Screwdriver Bit, Identification: step 1, image 1 of 2 Choosing the Right Screwdriver Bit, Identification: step 1, image 2 of 2
    • The screw bits in our iFixit bit kits have engraved prefixes that indicate the head type. These prefixes are typically followed by a number that indicates bit size. For example:
    • PH2 - (Phillips #2) A large Phillips bit.
    • PH0 - (Phillips #0) A medium Phillips bit.
    • PH000 - (Phillips #000) A small Phillips bit.
    • Choose the bit size that fills the screw head entirely. A bit that is too big or too small will not seat properly, and you'll end up with a stripped screw.
  2. Choosing the Right Screwdriver Bit: step 2, image 1 of 2 Choosing the Right Screwdriver Bit: step 2, image 2 of 2
    • If you find yourself scratching your head over identifying the bits in your tool kit, feel free to use this reference list.
    • Physical bit shape followed by proper name.
    • Bit size.
    • If there is no prefix engraved in your bit, simply use the full proper name and size when using your bit in a guide. (For example: "Use a 1.5 mm Flathead bit to remove the two 5 mm case screws.")
  3. Choosing the Right Screwdriver Bit, J vs PH: step 3, image 1 of 2 Choosing the Right Screwdriver Bit, J vs PH: step 3, image 2 of 2
    • Bits with the prefix "J" and "PH" are often thought to be the same bit. Don't be fooled by their similar appearance—they are quite different.
    • Phillips (PH) screws are designed to make a Phillips screwdriver cam out if too much torque is applied. This prevents damage to screws and screwdrivers or bits.
    • Japanese Industrial Standard (J) screws do not provide a cam-out option, and have 90 degree corners.
    • J (JIS) and PH (Phillips) driver bits are not always interchangeable. As you can see, they do not share identical physical properties.
Richard
29,761 Reputation
11 Guides authored
iFixit Member of iFixit
Staff
136 Members
16,573 Guides authored
Past 24 Hours: 141
Past 7 Days: 1,024
Past 30 Days: 4,114
All Time: 219,703
