Changing the hinges of the Why! NK50SZ
  1. Changing the hinges of the Why! NK50SZ, Battery 1: step 1, image 1 of 3 Changing the hinges of the Why! NK50SZ, Battery 1: step 1, image 2 of 3 Changing the hinges of the Why! NK50SZ, Battery 1: step 1, image 3 of 3
    • Unlock the right latch and hold the left latch unlocked with your finger.
  2. Changing the hinges of the Why! NK50SZ, Battery 2: step 2, image 1 of 2 Changing the hinges of the Why! NK50SZ, Battery 2: step 2, image 2 of 2
    • While holding the left latch, lift the battery from the slot under the right latch.
  3. Changing the hinges of the Why! NK50SZ, Cover: step 3, image 1 of 3 Changing the hinges of the Why! NK50SZ, Cover: step 3, image 2 of 3 Changing the hinges of the Why! NK50SZ, Cover: step 3, image 3 of 3
    • Unscrew the 6 screws, then lift the cover.
  4. Changing the hinges of the Why! NK50SZ, Keyboard (1): step 4, image 1 of 3 Changing the hinges of the Why! NK50SZ, Keyboard (1): step 4, image 2 of 3 Changing the hinges of the Why! NK50SZ, Keyboard (1): step 4, image 3 of 3
    • Remove the two screws (red circles).
    • Partially straighten a paperclip. (or use an appropriate tool if you have one.)
    • Insert the improvised tool into the orifice (red arrow) marked by the icon (red square)
  5. Changing the hinges of the Why! NK50SZ, Keyboard (2): step 5, image 1 of 3 Changing the hinges of the Why! NK50SZ, Keyboard (2): step 5, image 2 of 3 Changing the hinges of the Why! NK50SZ, Keyboard (2): step 5, image 3 of 3
    • Insert the paperclip into the orifice to unlock the keyboard preparatory to removing it in the next step.
  6. Changing the hinges of the Why! NK50SZ, Keyboard (3): step 6, image 1 of 3 Changing the hinges of the Why! NK50SZ, Keyboard (3): step 6, image 2 of 3 Changing the hinges of the Why! NK50SZ, Keyboard (3): step 6, image 3 of 3
    • Lift the keyboard, without removing it.
    • Locate the ribbon cable attaching it to the motherboard. (red rectangle)
    • After you open the latch, remove the cable (red arrow).
    • If it is a backlit keyboard, there is a second, narrow cable (see next step for location) that must also be unplugged. Failure to disconnect either or both before attempting to remove the keyboard can damage the cables and necessitate replacement or repair.
    • Now you can remove the keyboard.
  7. Changing the hinges of the Why! NK50SZ, Keyboard (4): step 7, image 1 of 1
    • If you are replacing the original keyboard with a backlit one, you need to remove the adhesive strip and connect the second narrow flex-cable to the jack ( red circle).
  8. Changing the hinges of the Why! NK50SZ, Heatsink/Fan Assembly: step 8, image 1 of 3 Changing the hinges of the Why! NK50SZ, Heatsink/Fan Assembly: step 8, image 2 of 3 Changing the hinges of the Why! NK50SZ, Heatsink/Fan Assembly: step 8, image 3 of 3
    • You must unscrew the six screws (red circles) and disconnect remove the fan lead.
    • The assembly can now be carefully lifted out.
  9. Changing the hinges of the Why! NK50SZ, Bottom Cover/Case (1): step 9, image 1 of 3 Changing the hinges of the Why! NK50SZ, Bottom Cover/Case (1): step 9, image 2 of 3 Changing the hinges of the Why! NK50SZ, Bottom Cover/Case (1): step 9, image 3 of 3
    • Disconnect the three ribbon cables (orange rectangles)
    • Remove the five screws (red circles)
    • Insert a pick between the edges of the upper and lower case and slide it as depicted.
  10. Changing the hinges of the Why! NK50SZ, Bottom Cover/Case (2): step 10, image 1 of 3 Changing the hinges of the Why! NK50SZ, Bottom Cover/Case (2): step 10, image 2 of 3 Changing the hinges of the Why! NK50SZ, Bottom Cover/Case (2): step 10, image 3 of 3
    • Continue with the pick to disengage the plastic 'clips' along both sides.
    • Remove the Bottom cover.
  11. Changing the hinges of the Why! NK50SZ, Motherboard (1): step 11, image 1 of 3 Changing the hinges of the Why! NK50SZ, Motherboard (1): step 11, image 2 of 3 Changing the hinges of the Why! NK50SZ, Motherboard (1): step 11, image 3 of 3
    • Position the device keyboard down and peel off the adhesive strip (orange square).
    • Disconnect the cables (orange square) and remove the three screws (red circles).
    • You must also disconnect the antenna leads from the Wifi card (green circle) if it hasn't already been removed. It isn't necessary to remove the WiFi card to remove the motherboard. unless you are replacing it, of course.
  12. Changing the hinges of the Why! NK50SZ, Motherboard (2): step 12, image 1 of 1
    • The motherboard can now be removed.
  13. Changing the hinges of the Why! NK50SZ, Right Speaker: step 13, image 1 of 1
    • Disconnect the cable (orange square). Then peel off the adhesive (Yellow rectangle). Disentangle the leads from their routing.
    • Now you can remove the right speaker (red square)
  14. Changing the hinges of the Why! NK50SZ, Left Speaker: step 14, image 1 of 1
    • Disconnect the cable (orange rectangle) and remove the left speaker (red rectangle)
  15. Changing the hinges of the Why! NK50SZ, DC Socket: step 15, image 1 of 1
    • Disconnect the cable (orange rectangle) and remove the two screws (red circles)
  16. Changing the hinges of the Why! NK50SZ, Multi-Function Board: step 16, image 1 of 1
    • Remove the screw (red circle) and disconnect the ribbon cable (orange circle).
  17. Changing the hinges of the Why! NK50SZ, Top Cover/Case (1): step 17, image 1 of 3 Changing the hinges of the Why! NK50SZ, Top Cover/Case (1): step 17, image 2 of 3 Changing the hinges of the Why! NK50SZ, Top Cover/Case (1): step 17, image 3 of 3
    • Unscrew the three screws (red circles) and remove the big black plastic part.
    • Unscrew the screws (red circles).
  18. Changing the hinges of the Why! NK50SZ, Top Cover/Case (2): step 18, image 1 of 3 Changing the hinges of the Why! NK50SZ, Top Cover/Case (2): step 18, image 2 of 3 Changing the hinges of the Why! NK50SZ, Top Cover/Case (2): step 18, image 3 of 3
    • Remove the Black plastic part (as the red arrows direct) photo one.
    • Lift the metal part (orange rectangle)
  19. Changing the hinges of the Why! NK50SZ, Top Cover/Case (3): step 19, image 1 of 3 Changing the hinges of the Why! NK50SZ, Top Cover/Case (3): step 19, image 2 of 3 Changing the hinges of the Why! NK50SZ, Top Cover/Case (3): step 19, image 3 of 3
    • Remove the three screws (red circles) and remove the black plastic part.
    • Lift the metal piece (orange rectangle), unlatch the cable connector (green rectangle) and remove the adhesive-backed 'tape' (yellow rectangle).
  20. Changing the hinges of the Why! NK50SZ, Top Cover/Case (4): step 20, image 1 of 2 Changing the hinges of the Why! NK50SZ, Top Cover/Case (4): step 20, image 2 of 2
    • disconnect the cable (orange circle) secured by the adhesive tape.
    • Remove the top Cover
  21. Changing the hinges of the Why! NK50SZ, Screen Frame (1): step 21, image 1 of 3 Changing the hinges of the Why! NK50SZ, Screen Frame (1): step 21, image 2 of 3 Changing the hinges of the Why! NK50SZ, Screen Frame (1): step 21, image 3 of 3
    • Insert a pick into the bottom edge of the frame and slide it as depicted. (red arrows)
    • Avoiding force, carefully unclip the lower part by hand.
  22. Changing the hinges of the Why! NK50SZ, Screen Frame (2): step 22, image 1 of 3 Changing the hinges of the Why! NK50SZ, Screen Frame (2): step 22, image 2 of 3 Changing the hinges of the Why! NK50SZ, Screen Frame (2): step 22, image 3 of 3
    • Heat the upper part of the frame with a hair dryer to weaken (soften) the adhesive tape beneath.
    • Do not heat in the same place for long, it is important to keep moving your focus to avoid damage. Try to spread the heat evenly.
    • Insert the pick under the top edge of the frame, slide it as depicted.
    • Remove the screen frame.
  23. Changing the hinges of the Why! NK50SZ, Hinges: step 23, image 1 of 1
    • Unscrew the six screws (red squares), as well as the two (red circles).
    • Remove the hinges
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
Juan Garcia is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,538 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 58
