Unscrew the 2 fixing screws of the housing
Remove the housing
Using a flathead screwdriver, remove the clip that holds the high pressure outlet fitting from the pump to the reel.
Pull the connection facing you
Spread the 2 retaining bearings of the reel outwards.
Then remove the reel one side at a time.
Unscrew the 6 fixing screws marked with arrows.
Tilt the device on the front to access the last 2 fastening screws located under the product marked with arrows.
Then lay the device flat, and unscrew the plastic nut from the water inlet pipe.
Remove the front panel upwards.
Return the product to its vertical position on its wheels.
Unscrew the screw indicated by the arrow to release the bearing from the reel to remove the pump outlet hose.
With the mounting screw removed, slide the bearing as indicated by the arrow.
Then pull up to remove the bearing from the pipe.
Then remove the front panel.
Remove the button facing you.
Unscrew the 2 screws as indicated in order to disengage the support.
Then unscrew the 6 screws and remove the cover to access the electrical connection.
Remove the switch from its housing.
Disconnect the red power cable from the On/Off switch
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
