Introduction
This Guide covers how to properly change the engine oil and filter on a Fiat 500 Hybrid
Lift the dipstick cap.
Place a drain pan below the drain plug.
Loosen the drain plug using a 13mm wrench, then finish removing it by hand.
loosen the oil filter by hand or with the help of a filter wrench.
Pre-fill the oil filter with new oil.
Lightly lubricate the o-ring of the filter with the oil used to fill it.
Tighten the filter by hand so as to be able to unscrew it more easily next time.
Replace the engine cover and tighten the 10mm bolt moderately.
Lower the vehicle
Fill the crankcase with engine oil until it reaches the maximum level.
Start the engine and let it run a few moments to allow the filter to fill and the oil spread throughout the whole block.
Stop the engine and wait a few minutes the oil to flow down into the oilpan.
Check the oil level and adjust if needed.
Congratulations ! You've just changed the oil on your Fiat 500 ! Don't forget to reset the drain counter.
2 other people completed this guide.
Special thanks to these translators:
100%
Juan Garcia is helping us fix the world! Want to contribute?
Start translating ›
