Change the Presser Foot on a Sewing Machine
  1. Change the Presser Foot on a Sewing Machine, Presser Foot: step 1, image 1 of 2 Change the Presser Foot on a Sewing Machine, Presser Foot: step 1, image 2 of 2
    • Set the sewing machine needle to the upright position by turning the balance wheel towards you.
    • Release the presser foot lever by sliding it up.
    • The presser foot will just fall out. Be ready to grab it.
  2. Change the Presser Foot on a Sewing Machine: step 2, image 1 of 3 Change the Presser Foot on a Sewing Machine: step 2, image 2 of 3 Change the Presser Foot on a Sewing Machine: step 2, image 3 of 3
    • Pull the presser foot down and slide it off the peg on the machine.
    • Be careful not to break the needle.
  3. Change the Presser Foot on a Sewing Machine: step 3, image 1 of 3 Change the Presser Foot on a Sewing Machine: step 3, image 2 of 3 Change the Presser Foot on a Sewing Machine: step 3, image 3 of 3
    • Grab your desired presser foot, and orient it foot-down.
    • Take the foot at an angle and slide the hole in the top of the presser foot onto the peg on the sewing machine.
  4. Change the Presser Foot on a Sewing Machine: step 4, image 1 of 2 Change the Presser Foot on a Sewing Machine: step 4, image 2 of 2
    • Slide the presser foot lever down to lock the new foot in place.
    • Be sure to check your manual to see if you need to adjust the needle position. If it's not correctly adjusted, you may hit the needle on the presser foot and break the needle while sewing.
Finish Line
Brittany McCrigler
89,014 Reputation
131 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,817 Guides authored
One Comment
Tolle Anleitung, vielen Dank und wie kann man die Drehteile ersetzen wo die Fäden reinkommen? Kann ich das selbst ersetzen oder muss ein Fachmann her?
Ben - Reply
Past 24 Hours: 12
Past 7 Days: 99
Past 30 Days: 365
All Time: 48,729
