Casdon Dyson Ball On/Off Switch Replacement
  1. Casdon Dyson Ball On/Off Switch Replacement, Battery: step 1, image 1 of 1
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball On/Off Switch Replacement: step 2, image 1 of 1
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
    It take 4 C batteries. Hope this helps!
    Ladii Lee - Reply
  3. Casdon Dyson Ball On/Off Switch Replacement, On/Off Switch: step 3, image 1 of 1
    • Remove four 9.2mm (0.32 in) screws from the back of the vacuum using the PH00 screwdriver.
  4. Casdon Dyson Ball On/Off Switch Replacement: step 4, image 1 of 1
    • Remove the cover to the on/off switch by pulling up on the cover from the front of the vacuum.
  5. Casdon Dyson Ball On/Off Switch Replacement: step 5, image 1 of 1
    • Cut the two wires connected to the on/off switch using a set of wire cutters.
    What is underneath the little board that’s circled and in between that and the black plastic on off switch as my sons has broke I put it back together as so but it doesn’t work but if I put the screwdriver on the metal solder point of the wire it comes on so I’m guessing there should be a metal bit that slides across underneath the bit circled in the picture to make the connection on or off.
    benrandle - Reply
  6. Casdon Dyson Ball On/Off Switch Replacement: step 6, image 1 of 1
    • Remove the two 9.2mm (0.32 in) screws which hold the on/off switch to the vacuum using the PH00 screwdriver.
  7. Casdon Dyson Ball On/Off Switch Replacement: step 7, image 1 of 1
    • Remove the on/off switch by pulling it away from the vacuum with your fingers.
    • Replace the faulty on/off switch with the new on/off switch.
    • Solder the new on/off switch's wires to the vacuum's wires using a soldering station.
    Nice! Got any part numbers/sources for a replacement switch?
    Paul DiGioia - Reply
Seldon Price
612 Reputation
5 Guides authored
IUPUI, Team S3-G5, Harley Fall 2017 Member of IUPUI, Team S3-G5, Harley Fall 2017
IUPUI-HARLEY-F17S3G5
3 Members
10 Guides authored
One Comment
Great instructions but where can you purchase the on of switch and what is the part number?
debbyh1024 - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 2,050
