Introduction
This guide will help you replace an LCD screen that is cracked, broken , or otherwise malfunctioning. Repair is fairly easy to do. One must be mindful of the many small screws that need to be removed to access the screen.
Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
To remove the hand-strap, pull the Velcro strip through the leather pad.
Press in the battery release tab located on the bottom of the camera.
Slide the battery out from the body.
Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
Keep track of what screw goes where. There are several sizes and thread pitches to keep track of!
Remove the LCD display from the camera body.
The LCD screen cannot be removed on the R600 without removing two screws found on the inside of the body. To get to those screws you have to remove the entire "insides" of the camera.
Can you replace the touch screen on the R500 by removing the 2 screws on the hinge side of the display or do you have to remove the entire insides of the camera
6 Comments
Where did you find the replacement LCD screen at? Specifically I am looking for the Vixia HF M41A version
I can’t find the replacement lcd for my model canon vixia hf R600, can you point me in the right direction?
Very nice step by step guidance. Where can I find the Replacement lcd screen for Canon Vixia HFR 600 camera. Will appreciate that!
Thanks!
I think this is it: https://www.aliexpress.us/item/325680404...
But, I'm about to purchase it, and try it.
